Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Candy Washing Machine
- This topic has 14 replies, 4 voices, and was last updated 9 years, 1 month ago by
Killer13.
February 23, 2017 at 3:37 pm #90671
Killer13
ParticipantHello
I have a candy washing machine model number GO F 662 S
It refusing to spin so i checked the usual things and found that the brushes are nearly on the metal but still making good contact with the motor .
Would this be the reason that the im getting no spin from the machine ?
Thanks in advance
February 23, 2017 at 3:47 pm #445565Martin
ParticipantRe: Candy Washing Machine
Most definitely.
February 23, 2017 at 3:56 pm #445566Killer13
Thanks for the fast reply Martin
Im having trouble finding the correct brushes for the machine could you point me in the right direction ?
There are loads on ebay and amazon that say the are for the Ceset motor but none seem to list my machine
February 23, 2017 at 4:14 pm #445567kaibart
ModeratorRe: Candy Washing Machine
Email the spares shop on the website with the 31 number inside the door and they will find the correct brushes for you
February 23, 2017 at 4:35 pm #445568Martin
ParticipantFebruary 25, 2017 at 2:46 pm #445569Killer13
What exact ones do i need . I emailed the shop but did not get a reply and the link takes me to a page with various diffrent brushes.
February 25, 2017 at 3:27 pm #445570Martin
You take the brush unit out and compare the various photos to ID the ones you need. 💡
February 25, 2017 at 3:39 pm #445571don
Killer13 wrote:What exact ones do i need . I emailed the shop but did not get a reply and the link takes me to a page with various diffrent brushes.
Apologies for the shop not getting back to you but we have been away on our annual conference for the last couple of days. I know Dave has over a hundred emails to reply to.
In the meantime can you post up the 31 number from the machine label as there is more than one version of your appliance. I will then be able to point you in the right direction for the correct carbons.
DonFebruary 26, 2017 at 6:54 pm #445572Killer13
Thank you Don
The number on the label is 31004043 1108 0022
February 26, 2017 at 7:46 pm #445573don
Had a look on the Hoover Candy tech site the carbon brushes are not listed. It may be that there is no spare part available, I can find the motor here which obviously seems rather silly.
Leave your email enquiry with Dave as he has built up a big database of cross referencing for all sorts of parts. I do hope he can help.
Don
February 26, 2017 at 8:17 pm #445574Martin
If the OP gave us the make of the motor having read the label attached to it then that would help enormously. From what I have managed to determine, it may well be a CESET motor, in which case these brushes should fit…..
February 26, 2017 at 8:57 pm #445575Killer13
It is a CESET motor
MCA 52/64-148/CY50
Cod. 41 024719
Copied this direct from motor label. Couldn’t figure out how to upload a picture
February 26, 2017 at 9:19 pm #445576Martin
Killer13 wrote:It is a CESET motor
So when you compare your motor brushes with those in the photo link, are they not the same? (You need to compare the screw hole fixings as well as the locating lugs underneath to be sure) 😀
February 27, 2017 at 12:18 pm #445577Killer13
The ones in the link provided do not look the same .
February 27, 2017 at 3:34 pm #445578Martin
Killer13 wrote:The ones in the link provided do not look the same .
Well at least you know now to look for CESET brushes. This website sells all variants of that make so I feel sure we have at least pointed you to the source of suitable replacements. 🙂
