Candy WM EVO14104L/1-80
  • #96215
    pmb
    candy Washing machine evo14104L/1-80. Display lights up but nothing happens when I press start, no fault code .
    its a machine I collected when I installed their new machine,
    guess it’s the PCB , it’s a special order with connect, anyone had this fault.
    #462702
    be careful with the pcb there are a few changes depends on serial no
    found the test routine if you want it
    have you checked child lock and door lock
    also look at board and find door triac and look for damage
    if its got brushes check them first
    murv
    I would check the display module (start tact switch) and the plastic module container.
    #462704
    pmb
    Thanks door lock lock and brushes were the first things I checked, also child lock, so I am scraping it.
    Candy and Hoover are not an expensive machine,
