Hi I also have trouble with a Candy WDXCC4851-80 which if you select the 59 minute wash won’t start. Also if you put it on the quick program, there are 3 options for time but it will only start if you select the quickest 14 mins. I tested and disconnected the heater but it didn’t make a difference. Is this a PCB fault?
Thanks, Darren
