Cannon C60LCIK gas oven
  • #63947
    Micky 32
    A friend has one and he told me when he switches on the oven it lights but the ignitor keeps clicking for a minute or so after so i had a quick look this evening..
    What i found was when you first light it the flame is very low and then after a min comes on full belt. I’m guessing the flame being too low for the first min or so is causing the ignitor to keep activating because it stops when the flame comes on full.
    The oven is just over a year and there was a problem with a low flame that was repaired under warranty but still not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} since. What causes this fault anyone know?
    #355600
    Re: Cannon C60LCIK gas oven
    the spark generator senses the flame so if it goes out it relights it obviously the flame is too low to convince the circuitry that its lit. you could check the burner to see if there are any blocked holes around the electrode
    Jazzmeister
    Or adjust the electrode a little closer to the flame!
    Jazz
