Cannon Camberley LPG Cooker poor grill performance
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Cannon Camberley LPG Cooker poor grill performance
  • #36217
    andytw
    Have an LPG Cannon Camberley cooker.
    It gas a top oven which also serves as a grill by using different burners.
    The grill lights but doesn’t perform as well as it used to.
    Am happy to get Corgi involved, just interested as to whether this is likely to be fixable. Will not be doing it myself.
    andytw
    #250099
    Re: Cannon Camberley LPG Cooker poor grill performance
    I’m not familiar with the model Andy but it will likely be blocked jets which is the cheapest problem as it should be a simple case of clearing them/it or replacing which shouldn’t be too expensive.
    Then you get into the expensive stuff, FSD, burner assembly or gas stat none of which you will see change out of £100-150 to swapout.
    HTH
    andytw
    Well, I thought I would at least have a non disruptive look. The jet is visible in the side of the grill compartment. A gentle clean with a small wire and the grill is back in business.
    Thanks for the tip
    andytw
    #250101
    Pleased it worked for you, Andy.
    Future readers take note that probing a gas jet with any rigid object is not to be recommended as there is a significant risk of damaging the jet orifice and upsetting the air/gas mixture. The task should really be left to a suitably qualified – CORGI – repairer.
