Cannon CH60GTCF
  • #78948
    folleyball
    Happy new year everyone.
    Called at this gas cooker today to replace the door roller catch on the main oven C00118116.
    Thought it would be a simple case of removing the side and replacing. But I should know by now these things are never simple :rolls: .
    I can’t get the gas hob off at the top. There are a couple of screws behind the control panel I need to remove but I cant get to them.
    The cooker is two years old.
    Just wondered if anyone has come across the same problem.
    #407450
    razor
    Re: Cannon CH60GTCF
    side panel removal – only remove 1 panel at a time…
    remove main door assembly , if removing left hand side panel only
    undo 11 screw at the front left hand side including the door hinge fixings or the 7 screws at the front right hand side, to whichever panel you require to remove
    undo the 7 screws from the left hand or right side panel rear
    pull the relevant side panel clear.
