Cannon Cooling Fan
  • #89867
    oldsodchops
    Does anybody have a wiring diagram for a Cannon 20152E as the cooling fan motor stays on permanently? I cannot find the Cut-in stat anywhere! The neutral from the fan motor goes directly to the top oven switch.
    Thanks!
    #442802
    aqualectric
    Re: Cannon Cooling Fan
    There is a cut in thermal limiter in line to the fan motor. They are usually found on the top of the appliance on or to one side of the vent that goes from fan to the outside (front of machine above the door handle). Notice that it is a CUT IN ‘stat; therefore it will test as open circuit at room temperature and will make on rise. It is a small black round item with two upwards facing tags and is fixed by two screws on the rim of the ‘stat.
    Remove hob and ye shall find…… it will be there as it is a listed part. 😉
    #442803
    oldsodchops
    Thanks for your comments however I have replaced cut In stats on several occasions and know where they are usually located. As stated above the neutral from the fan motor goes directly to the top oven switch and the live supply is directly to the live mains terminal block hence the desire for a wiring diagram. I suspect the top oven stat is faulty but I cannot find the cut in stat even though it is shown in the partfinder diagram.
