Cannon DF Cooker 10583G Mk3 Tech info
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Cannon DF Cooker 10583G Mk3 Tech info
  • #64653
    Pigpen4
    Does anyone have a wiring diagram for a Cannon 10583G Mk3 Dual Fuel cooker, please?
    He tells me on the phone:
    I went to change the bulb, but it smashed and I couldn’t get it out, so I took the back off and the back of the bulb holder was all corroded.
    I isolated the wires from the bulb, now the main oven fan is on all the time and when you switch the top oven on, the clock goes off.
    I’d rather go armed with a wiring diagram, if possible, as I feel sure he’s done a bit more than just isolate the wires from the bulb.
    Thanks, Pigpen.
    #357657
    BobHope
    Re: Cannon DF Cooker 10583G Mk3 Tech info
    please PM me an email addy and i will send some info.
    Bob.
    EMAIL sent.
    #357658
    Pigpen4
    Thanks for your help, Bob.
    An update:
    He’d isolated the two neutral wires separately from each other, thereby removing the neutral from the top oven lamp and the clock.
    Bulb holder wasn’t corroded – it had burnt out when he’d shorted the cables across trying to remove the broken bulb.
    When fan oven was turned on and it shorted at the back of the bulb holder, it had welded the contacts shut on the main oven selector, which is why the fan was permanently on!
    Pigpen.
