Cannon c60dpxf
Main fan oven if set to 180c heats but beeps as if at temperature but it’s only at 150c
If set to 210c it beeps at 180c
In both cases if left for a further 15 minutes it will get up to the set temp and stay there ok if empty. Although when food is put in the temp dipped 25c and seemed to struggle.
Further to this if set at a temp and it beeps and temp indicator goes out, if the temperature nob is turned to a higher temp the indicator doesn’t come back on to note oven not at temperature.
On the top oven this function works fine
Spoke to an engineer he suggests the main board and told me he couldn’t test it and won’t risk it so phone hot point helpline, they want £240 for an extended warranty.
Any ideas ? Or should I pay the £240
