Cannon gas cooker model 10305G oven main burner failure
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Cannon gas cooker model 10305G oven main burner failure
  • #23580
    kd
    My gas oven fires up immediatly on low fire but does not increase to main burner rate. The flame failure T/C looks fine ( not burnt ) Is the problem likely to be the oven thermostat rather than the FFD.
    Can I gain access to the FFD or oven stat without removing the cooker. I am COGI reg. but with little experiance with cooker maintenance.
    Keith
    #198651
    Re: Cannon gas cooker model 10305G oven main burner failure
    kd wrote:I am COGI reg. but with little experiance with cooker maintenance.
    Sounds as though it could be the oven varistor at fault here? Not an appliance to mess with unless you are sure where to look to be honest. Best call in Cannon and get their engineer to check it out. 😉
