Cannon Langdale Oven going out during cooking
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Cannon Langdale Oven going out during cooking
  • #44050
    Lark
    I have a Cannon Langdale Gas cooker which is 8 months old. During the last 8 weeks, the oven has gone out 4 times during cooking resulting in spoiled food. An engineer came out and said there was no problem with the oven but I can’t see how an oven can be operating correctly if it is going to go out part way through cooking. It also went out once when I turned the control knob down from gas 7 to gas 6.
    Could there be a problem?
    Should I get the engineer back?
    Lark
    #279614
    wards
    Re: Cannon Langdale Oven going out during cooking
    if the oven is controlled by an fsd,then you will probably find that this is the problem,when you ignite the oven do you have to keep the oven knob depressed when igniting and hold the knob in for 5-10 seconds once lit?if this is the case then that would be my first diagnosis.you should not attempt any repair on gas appliances,please call in a competent person to carry out any repairs.
    #279615
    kiddo66
    Get the engineer back,sounds like it has a thermocouple on the oven burner which may have a bad connection.
    #279616
    helo_75
    id ask him to put a new knob on it while he was there too
