Re: Cannon Pembroke – oven door handle loose
Update – got it fixed. For anyone else doing a search:
Removed inner glass from door (it needed a good clean anyway!), making sure there was a thick towel on the tiled floor beneath it. Tried reaching in through that opening with angled screwdriver but couldn’t get it sitting properly in screw-head (Pozidriv).
Removed screw at top of side panel (directly above catch housing and next to handle’s screw) and found there was enough flex in the panel to allow screwdriver in from the top. Fiddly – probably less than a quarter-turn each time – but eventually got it tightened enough (worked on basis it was driving into plastic and took it gently). Spent a long time cleaning glass and discovered it was actually transparent :boops:
Thanks iadom – your response encouraged my laziness to take a closer look and find a way 🙂
Cheers
Neil
