Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Cannon Windsor Mk2 Glass Top Bracket
- This topic has 8 replies, 2 voices, and was last updated 8 years, 5 months ago by
qb.
October 17, 2017 at 9:25 pm #92415
qb
ParticipantThe RH glass top bracket has come loose after the bolt somehow managed to come loose and fall out. How it got out is a mystery as there’s not enough space to persuade it to go back in.
The extruded aluminium side trim strip blocks easy access, and although there only appears to be one securing screw, the blasted thing won’t budge.
Before I revert to basic engineering and drill an access hole, anybody know how to get this off?October 18, 2017 at 7:07 am #451220don
ModeratorRe: Cannon Windsor Mk2 Glass Top Bracket
Model number would help please probably something like ?????G
DonOctober 18, 2017 at 8:42 am #451221qb
ParticipantRe: Cannon Windsor Mk2 Glass Top Bracket
It’s a 10296G. Looking at it, the trim strips look like they should pull out to the back, but removing the screw and inserting a narrow blade at the front end just moves the white plastic section above the control panel forward.
October 18, 2017 at 9:29 am #451222don
Is this the top cavity door or the lower one?
Don
October 18, 2017 at 9:54 am #451223qb
It’s the screw that holds the lid bracket onto the hinge assembly that’s come out.
October 18, 2017 at 10:29 am #451224don
Looking at the explosion it is not a DIY job I’m afraid as it would appear that the hob tray and trims need to be removed in order to replace the hinge.
This job would need to be carried out by a Gas Safe engineer. There should be one local to you from the register here Sorry but we have to be safe when it comes to gas.
DonOctober 18, 2017 at 11:54 am #451225qb
The hinge assembly is easily accessed behind the side panel but the hinge assembly actuates the top down hob shut off valve, so I don’t want to mess with that. Also, there’s no obvious way to stop the spring going wild!
I’ll revert to drilling an access through the trim panel to poke the screw through. It’ll be hidden when the cooker’s pushed back and that way, I’m not interfering with any functional components.Thanks for your help.
October 26, 2017 at 10:06 pm #451226qb
Finally got round to having a proper look at this yesterday and it turned into a ten minute easy fix, Three screws to release the side panel and two to release the hinge assembly. The spring isn’t loaded so it all went back together easily.
No need for a Gas Safe ‘engineer’.October 27, 2017 at 7:26 am #451227 -
