cannot identify this washing machine??? details below
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts cannot identify this washing machine??? details below
  • #19115
    TELL
    this m/c needs a door interlock, they look like these part no’s on connect’s site, they are 5031687691095, and 5031680202632.
    the washer is a B/I app. there is no make, or manafacturers reconition on this m/c whatsoever. the only thing i can give you is as follows..
    Mod BI 1000X H/C
    7807251 00 190799
    on the door it has as above,and
    J8005K04355 02-800670
    #181791
    aqualectric
    Re: cannot identify this washing machine??? details below
    Looks like it’s a Servis – you usually can tell by the small filter in the bottom right corner. Also the knobs have sprung-loaded shrouds that push back as you turn the timer / temp / drier knobs and return to a ‘flush fit’ when let go. Another giveaway is the very small pressed drum paddles. (and there are 4 of them, not your usual 3). If so, it’s a Servis clone. 😉
    Hope that helps!!
    Steve.
    #181792
    Siltal :
    http://www.ukwhitegoods.co.uk/modules.p … ic&t=15550
    Yep..
    It is definetly made by ARI SILTAL,your model is a standard washing machine,Interlock in stok with me or dave conway should also have one.
    bryan
    #181794
    TELL
    thanks lads for your help. bryan P.M. on its way to sort del etc. TELL..
    #181795
    BobHope
    hi tel
    i also have one in stock and im a bit closer than brian and im sure he wont mind 😉
    Bob.
    #181796
    No probs bob
    bryan
    #181797
    TELL
    thanks bob, will try for friday, and pop in.
    TELL..
