Hi, whenever we turn on the top oven, a grating noise is generated. It sounds like the cooling fan has got something stuck in it.
1- Where is the cooling fan located in the cooker, and is it possible to look at without dismantling it too much?
2- Could the oven be used, as although the fan is making an awful noise, there is still a draught coming out from below the control panel?
Finally, we are able to use the grill fine, which is slightly confusing. Surely the grill requires the cooling fan too?
Thanks,
Dominic
