Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Cant find number for pressure switch old type 2 level
- This topic has 12 replies, 5 voices, and was last updated 20 years, 4 months ago by
TELL.
December 11, 2005 at 8:05 pm #13993
TELL
Participantits for a servis washer Mod M911 its the (Gem 1100)
s/n 207200418. connect have a picture of the type i need..pt/n 5031680936858. all the part no’s im getting, is for the multi block fixing
down the centre of the pressure switch.
Ta TELL..December 11, 2005 at 9:06 pm #157428eastlmark
ModeratorRe: Cant find number for pressure switch old type 2 level
Thats the one you have to fit, the numbers on the terminals will be the same.
December 11, 2005 at 11:09 pm #157429TELL
ParticipantRe: Cant find number for pressure switch old type 2 level
ta, eastlmark. didn’t know if water levels would be different. it was going to be my last option if i couldn’t get the no: for it.
Ta TELL..December 12, 2005 at 12:01 am #157430TELL
pt no 5031680936858 p/switch on connect site. does masterpart do this one.
TELL..December 12, 2005 at 12:22 am #157431Penguin45
Been having a look at this Tell – there are 7 versions of this one 😯 – have you got the rest of the letters? After M911—? Serial number doesn’t help I’m afraid.
December 12, 2005 at 10:08 am #157432TELL
sorry chris all i got was m911, model type was a Gem 1100. place is miles away, and cust not in till late eve..
TELL..December 13, 2005 at 6:58 am #157433bobokines
You will find the part number printed on the pressure switch itself.
Bob
December 13, 2005 at 11:51 pm #157434TELL
Thanks Bob, sometimes these are just production codes/dates.
TELL..December 15, 2005 at 5:49 pm #157435TELL
ParticipantRe: HELP Cant find No: for pressure switch old type 2 level
Hi im back again about this pressure switch, the model is a servis for definite,mod M911 no other numbers or letter etc, have checked again. it just has GEM1100 on panel. and this is a 3 level switch not a 2 as put in before. it has 9 contacts 11-12-13 21-22-23 and 31-32-33. it does not have the multi block fixing down the centre, normal push on tags around the switch itself.
can anybody give the part no:STUCK NOW.
ta TELL..
PS. the numbers on the switch do not tally with the one conn-dist site, (multi block fittings). the numbers are 4-9219 40011700 P3-367A
95/50 115/65 135/95 340+65620+
hope this helps..December 15, 2005 at 6:27 pm #157436Dave_Conway
520002100 is the one I think, certainly has a 33 conection on it (picture on Connect’s site).
As Mark said though, it will be the block type but just fit the leads to the same numbers 🙂
December 15, 2005 at 6:36 pm #157437bobokines
Searching for SER40011700 on connect DVD converts to SER520002100
If you click on alternative on the properties box it shows the alternatve to be a two level switch 5031684817696 😕
Bob
December 15, 2005 at 6:42 pm #157438Dave_Conway
Yeah, I saw that 😕
A mistake I think in two ways, the alternative is also a 3 level (9 terminals visable) so the desription is wrong, it’s also an Ariston apparently.
December 15, 2005 at 7:02 pm #157439TELL
thanks lads checking that up now, got me pulling me hair owt, ps. posted subject again under 3 level switch. had a stutter with me fingers.
TELL.. -
