Re: Can’t find the fridge drain!
The drain is behind the rear panel in the freezer, You may not have defrosted it enough.
The drain runs through the insulation so can take up to 48 hours to defrost unless you dismantle the rear panel and use a steamer.
The best way to defrost it is to get someone to look after your food and turn it off for 48 hours and leave the doors open.
The drain ices because the NRV above the compressor can stick then the water can not run away and freezes in the drain.
Bob
