Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Can’t fit the condenser unit back in properly after cleaning
- This topic has 7 replies, 4 voices, and was last updated 12 years, 3 months ago by
AMPW.
December 29, 2013 at 4:38 pm #78776
AMPW
ParticipantHi. I’ve recently taken out the condenser unit in my Creda T622CW tumble dryer – to clean it. Now I can’t seem to fit it back in quite properly. More particularly; the door won’t shut. I think that’s because the unit isn’t in snugly enough; it’s sticking out, probably less than a centimetre, too far. I’ve stuck my arm through to see if anything’s blocking it at the back but all that’s there is a row of white knobbles (probably not the technical term) and I presume they’re meant to be there, to hold it in place. They’re pretty firmly fixed on. My husband thinks the fault may be with the door catch, but the door still closes fine when the condenser unit is removed.
Does anyone have any suggestions, however basic?
December 29, 2013 at 4:42 pm #406860Martin
ParticipantRe: Can’t fit the condenser unit back in properly after clea
You’re putting it in upside down or back to front?
December 29, 2013 at 4:44 pm #406861AMPW
I think I’ve tried every option on that…
December 29, 2013 at 7:36 pm #406862iadom
ModeratorRe: Can’t fit the condenser unit back in properly after clea
Sometimes the back edges of the condensor unit warp over time, this can make it very difficult to refit, do they look a bit wavy?
December 30, 2013 at 11:31 am #406863AMPW
They do look a bit wavy! Oh good, I’m not going insane. So is there anything I can do?
December 30, 2013 at 11:41 am #406864iadom
Not easy, I have trimmed them a little with a Stanley knife, but on the odd one that has been really bad then a new (expensive) condensor was needed. 😥
Part number C00095577, around £76.00 :eeek:
December 30, 2013 at 12:59 pm #406865Andy jones
One thing I did once to get a customer out of trouble was to drill a few pilot holes top and bottom of the condenser and then use a piece of thin garden wire to pull the wavy bits into shape.
January 2, 2014 at 8:24 pm #406866AMPW
Thanks everyone, I’ve trimmed a little bit off the back and it’s gone back in okay. Just hope it doesn’t break down fatally any time soon…
