Can’t split Bosch Washer Tub
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Can’t split Bosch Washer Tub
Viewing 4 posts - 16 through 19 (of 19 total)
  • #336192
    Re: Can’t split Bosch Washer Tub
    bazza500 wrote:So I get it….. a dozen steak knives are lighter than a pair of snips?? 😀
    I knew someone was going to ask that :rolls: .
    To put it most clearly, my dear, so that you can understand 😀 : I only need to take the steak knives with me when I’m going to a Bosch clipped tub bearing job (i.e. once only so far, and in fact I used knives supplied willingly by the customer). Whereas, I take my sidecutters everywhere except to bed.
    Mike.
    #336193
    funkyboogy wrote:
    ps would butter knifes do or do they have to be steak knifes ?? ..
    I think butter knives might do but they would need to be of the narrow sort.
    Steak knives are more pointy and will go in ideal.
    Mike.
    #336194
    trotter
    The best way to split ANY tub is here
    http://uk.video.yahoo.com/watch/8062275/21344410
    #336195
    myfil
    The plastic clips are in groups of 3, so I chopped off the outer pair of each group with a hammer and sharp chisel (dead easy). The remaining clips I prized open and they were a great help when I reassembled the tub with the extra screws.
    You have to be careful with the Bosch water seal, to tap it in just flush with the top of the bearings tube. It is easy to push it in too far and it then rubs on the front bearing (unlike the Hotpoint ones, which are better designed)
    I must say it is a lot easier with two of you getting the tub in and out.
