Capacitor American F/F
  • #7424
    Kirk
    Went to an GE American F/F found Cap blown I was very surprised that it was an 80uf I’ve never had to fit one above a 40 even the Maytag I have at home is a 5uf.
    It was fitted with a Danfos SC18?? I don’t have an HRP book now to check anyone out there know?
    Thanks Kirk
    #123141
    Re: Capacitor American F/F
    Sure there is not a missing decimal point in there? Could aways parrallel up 4 20uf ones if you have the room!
    #123142
    jongriffin
    Hi think you will find with sc18 compressors 80uf is not unusual i usually fit 60-80uf with no call back.
    #123143
    BobHope
    Hi Kirk,
    80uf is normal on that compresser, this is a start capacitor the 5uf one on your maytag is a run capacitor.
    As john sugests any 60 to 80uf will work fine.
    hope that helps.
    Cheers Bob.
    #123144
    Kirk
    Thanks for your help Kirk.
    #123145
    This is interesting, does this mean that the compressors I sometimes see with both a capacitor and and a start relay use the cap as a ‘run’ capacitor (why?) This would explain an AEG I once had with a blown top cap that was still working fine.
    Were not capacitor start comps introduced along with hydrocarbons to provide a spark free start?
    Any info would be most helpful.
    Mark.
    #123146
    BobHope
    Hi Mark.
    The run capacitor is used to improve the efficiency of the compressor to achieve the A rating class, the run current drops quite a lot when the capacitor is in circuit. Some compressors will work without it fitted but not as efficiently.
    Cheers Bob.
    #123147
    thanks for the info Bob.
    #123148
    BobHope
    No problem Mark,
    if you need some specifiction on compressors or comparison charts let me know and i will copy what i have.
    Cheers Bob.
