Capacitor required
  • #20216
    rocker
    I am repairing a Admiral top loader washer, It requires a motor capistor have rang maytag they tell me a new motor only..the value written on side 189-227 mfd 165vac 60Hz being a USA.
    Does anyone know of a capacitor I could use.,as most capacitors are listed at much lower mfd values.
    many thanks john
    #186244
    Dave_Conway
    Re: Capacitor required
    Try RS components – http://www.rswww.com
    They should have something 🙂
    rocker
    Sadly Dave they cant help me, If I was a member they may have helped more.!! so if anyone can help, please do.
    Cheers John
    #186246
    Dave_Conway
    Eh ? 😕
    You can order online, you only need to register and pay with a card, RS part number 117-170 (put in search box, select RS part number) is a 200uf capacitor +/- 25{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} will the trick :tup:
    #186247
    😕 Strange, just looked at the RS site. They call it a motor starter capacitor but they also call it an electrolytic. I thought electrolytic capacitors were only suitable for DC circuits.
    #186248
    Dave_Conway
    Phidom wrote:I thought electrolytic capacitors were only suitable for DC circuits.
    Nope, they’re nearly all electrolytic types on domestic appliances 😉
    #186249
    rocker
    Thanks Dave have been on RS site and found this part.
    great to be able to obtain tec information on this site.
    cheers John
    #186250
    Ah, just been reading up:
    http://www.tpub.com/neets/book2/3f.htm
    Quote:
    “Since an electrolytic capacitor is polarity sensitive, its use is ordinarily restricted to a dc circuit or to a circuit where a small ac voltage is superimposed on a dc voltage. Special electrolytic capacitors are available for certain ac applications, such as a motor starting capacitor. Dry electrolytic capacitors vary in size from about 4 …..”
    Clear as mud 😀
