Capacitors
  • #58373
    bigkid
    Obviously the correct uf rated capacitor should be used when replacing but I was always under the impression, wrongly or rightly, that as a rule of thumb 10{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} either way was acceptable.
    I just replaced a 10uf with the nearest I had on the van, a 12.5uf, in a LG condenser tumble dryer.
    Anyone have any comments?
    #334346
    gandh1
    Re: Capacitors
    following your rule of thumb, 10{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of 10 is 1, = 11…
    used 8uf instead of 7.5’s but wouldnt wanna go much further outside those parameters… never tried it and my electronic knowledge is thin at best – just assumed too much of a boost will fry certains parts
    #334347
    ELDAR59
    Re: Capacitors
    the capacitors themselves have a tolerence value, normally +/- 5{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}
    taking this into account, your 12.5 uf cap could be just under 12 or just over 13, whereas your 10 could be 10.5.
    i wouldn’t have thought you were far out with what you’ve done.
    #334348
    bigkid
    Re: Capacitors
    Thanks all, the original was +7 -3 the replacement was +or- 5.
    Ordered a 10 anyway as the 12.5 was only a stopgap.
    #334349
    Re: Capacitors
    Years ago somebody, think it was Iadom, posted on here that as long as it was bigger it would be fine. I have since (temporarily) used a 7 in place of a 5 (Zan dw) without any apparent issue. Now regularly replace 4’s with 5’s when cheap 4’s out of stock and 7.5’s with 8’s which are usually cheaper.
    Mike.
    #334350
    Re: Capacitors
    leavemetogetonwithit wrote:Years ago somebody, think it was Iadom, posted on here that as long as it was bigger it would be fine.
    Not guilty your honour. :angel:
    #334351
    shaun67
    Re: Capacitors
    I have used bigger uf in computer monitors and motherboards without issues ..You should be fine .
    #334352
    Re: Capacitors
    Did a quick search. Subject has certainly been much discussed in the past.
    See capacitor values
    and Measuring capacitance
    Mike.
