This washer will start and pump out but after about 1 min the fault code E11 comes up.
can’t find any mention of Caple fault codes. I assumed it was a rebadged Smeg – which states E11 fault is with motor, but motor reads ok. If it’s a pcb fault which pcb is it likely to be the display one or the one at the front bottom of machine?
