Re: Caple D/W ?
Went back to this very early this morning, 😉
The little present from north of the border could not be delivered on Saturday because no one was at home. 😥 just collected it an hour ago, thanks Ken.
Using the service manual I have, which says on the front Dishwasher 2001,
60mm, issuing date 07/06/02 I had a closer look at the machine.
The door stat which I assume is the 45° stat, is OC which is correct according to this manual. The base stat under the element has one side OC, the other NC which again appears to be correct. I have heard mention of a manual reset cut out and there appears to be one in this wiring diagram but I have looked everywhere on this machine and cannot see one.
Do all Smeg dishwashers have a manual reset stat, if so where is it. ❓
Will be going back on Wednesday with the aforementioned present. 🙂
