Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Caple DI414 dishwasher no fill.
- This topic has 7 replies, 2 voices, and was last updated 12 years, 10 months ago by
jonnyveeee.
June 10, 2013 at 8:48 pm #75801
jonnyveeee
ParticipantHi chaps.
Ive got a Caple DI414 dishwasher that starts up & pumps as normal. The start light then starts flashing & there is no fill.
Im pretty sure it is made by Whirlpool but may be wrong. (The service number is 8545 414 15710)
Any help greatly appreciated as ever.
Jon
June 10, 2013 at 9:57 pm #396187electrofix
ModeratorRe: Caple DI414 dishwasher no fill.
it is whirlpool count the number of flashes its a fault code
can be up to 15 flashes then a short pause and repeats
June 16, 2013 at 3:52 pm #396188jonnyveeee
ParticipantRe: Caple DI414 dishwasher no fill.
Thanks Dave.. Just picked up your reply.
Ive now got water filling at the same time as washing (the valve was faulty) but it then beeps with 9 flashes..
Ive not got the codes for this machine.. Have you any ideas?
Cheers
Jon
June 16, 2013 at 5:25 pm #396189jonnyveeee
Just an update to my previous post.. The inlet valve is NOT opening again when I select a program after the initial pump out. Ive multimetered the inlet valve connection from the board & its sending out 120 volts, the start button is flashing 6 times.
I am able to get continuity from reed switch when I place a magnet near it..
Jon
June 17, 2013 at 9:48 am #396190electrofix
f6 water tap close ie no fill
f9 continuous filling
June 17, 2013 at 2:58 pm #396191jonnyveeee
Hi Dave.. Thanks for that.. Ive got full pressure water supply to the valve but the valve wont open at all. Have tested it for a supply & its getting 120(ish) volts.. Not the required 240 volts. Is there any other reason for this or do you think the main card is faulty?
Cheers .. Jon
June 17, 2013 at 4:16 pm #396192electrofix
120v from where to where. you should measure the voltage across the valve. a lot of these machine switch neutral so you will get live on both terminals when its off.
couple of thing you could check but first i would look for broken wires. a lot of these machines have a habit of breaking wires just at the bottom of the door where the wires bend due to the door hinge. be careful a lot of the wires are the same colour so take it apart with care in case you have 2 breaks and cant guess which is whichDave
June 17, 2013 at 5:28 pm #396193jonnyveeee
Yep the 120v was across the valve when it was supposed to be open.. (Its supplied from a module at the bottom of machine). Then came the 6 flashes.. I will check the wiring at the door hinge as you say.. Have definitely seen faults in this area on other dishwashers… Thanks for your help with this machine Dave.. If this doesn’t crack it I think he may buy another one but will at least give it one more attempt.
Cheers
Jon -
