caple DI440 diaphragm switch
Home Forums Public Support Forums Help And Support Dishwasher Help Forum caple DI440 diaphragm switch
  • #59509
    Righty
    Hi , My Caple DI440 has been giving me an error code of 4 green lights and bleeps , i reset the start buttons and it used you work and finish the cycle . It now errors more often. Looking around on the web the faulty part could be a diaphragm switch on the sump (3 o’clock position) . I thought that maybe there was some grime in it so i used a cable tie to clear it …………….before you shout , damage was done . I think i have punctured it , i now have water leaking from it . so my questions are
    1. Would that diaphragm thing give me that error ?
    2. If it does , i need to replace it , how does it come off ?
    thanks for reading
    Righty
    #338460
    Righty
    Re: caple DI440 diaphragm switch
    Update , i have managed to change the pressure sump switch with a new one so have stopped the leak , have just put it a quick wash to test it and 10 mins the dreaded 4 beeps and flashing 4 lights . Have reset the start button and it finished the cycle . Seems to bleep when it starts to pump/drain .
    What area now should i be looking ?
    thanks
    Righty
    #338461
    Righty
    Another update, i can perform a rinse no problem . But on every other cycle it stops and gives the 4 bleeps needing a re-set . The most resets needed to complete a 65 C wash was 5.
    model number 854544015710
    if you can help, thanks
    righty
