CAPLE DI604 ERROR
  • #49341
    shed7
    HAVE A DI1604 THAT FLOODED AND BEW RCD, AFTER DRYING OUT HAVE NOW GOT PWER BACK BUT NO PROGRAM LIGHTS , LIFTED ARM ON MICRO SWITCH IN FLOAT CHAMBER NOW GOT FIRST 3 LIGHTS FROM LEFT CONTINUOUSLY FLASHING AND A CONSTANT BLEEP
    NEED TO KNOW WHERE TO GO FROM HERE ,
    ONCE POWERED OFF NEED TO GO THROUGH SAME PROCESS TO GET PROGRAM SIDE WORKING
    #299607
    Re: CAPLE DI604 ERROR
    Lifting the microswitch activates the anti-flood mode – the 3 l/h lamps flashing is that code. If the breaker popped, it’s entirely possible that whatever shorted has wiped out the pcb. It happens regularly on these Chinese machines.
    shed7
    thanks penquin , so would haVE TO FIND SHORT AND CORRECT PRIOR FITTING NEW BOARD OR NEW BOARD WOULD BE OPPED ASWELL?????
    #299609
    Yup. Unfortunately, the prime exploding culprit is the circulation motor. The combined cost of replacing the two will cost more than the dishwasher when it was new……
    Sorry,
