Caple DishwasherDI617 Error 1
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Caple DishwasherDI617 Error 1
  • #62455
    Steven
    Hi I have this machine with Error 1, only happens towards the end of the cycle? 😕
    Run through test procedure and nothing obvious.
    All clean inside no blockages in pressure chamber, heating and washing ok.
    It has a aqua stop/external valve which could be sticky?
    I know the pcb are not that reliable but anyone come across other known fault with this model?
    Cheers
    Steven
    #350165
    Steven
    Re: Caple DishwasherDI617 Error 1
    Hi guys
    Any one have any ideas on this one. Still having problems 😳
    Have changed the PCB and flow switch, still error out just before the drying cycle.
    It can also error 1 after a minute of starting?
    Reset and off it goes until just before the drying again will error out.
    Checked the flow meter thats seems ok, all wiring appears ok, washing and heating once going?
    So stumped a bit now 😕 to top it all have same fault yet on DI614?
    Would appreciate any help?
    Dont say you have a crusher 😆
    Surely someone has come across this fault as well
