Caple Fridge Freezer
  • #90740
    dgethin
    I have had a integrated Caple fridge freezer R1736 for about 3 years, lately I have had a lot of ice in the top of the drawer of the freezer. I understand every day a heater comes on to defrost the coils, when this happens the water drips into the drawer and freezes. I do not fancy trying to get the freezer out of the unit. There is a panel at the back of the freezer inside, with 4 screws, would I find anything here to cure the problem?
    Many thanks to anyone who answers!
    #445802
    Re: Caple Fridge Freezer
    the first thing to try is a total defrost. it may be frost free but its not totally true and they can ice up
    switch off and leave doors open for about 48 hours and try again
    dgethin
    Thanks for the reply, I have done a defrost without any success!
    #445804
    all self defrost units have a drain hole that lets the water get out and normally goes down a tube to a tank on top of the compressor where it will evaporate
    check this tube is clear
    dave
    #445805
    dgethin
    In the freezer section, there is no drain hole, but there is a panel with four screws at the back of the freezer on the inside, is there liable to be a drain hole behind the panel?
    #445806
    at the back of the freezer you will have an evaporator. below this will be the drain hole
    this unit is common to all self defrosting freezers and is at the back of the freezer behind the panel
    if you panel is a large cover you will find this unit behind it
    dgethin
    I think I will have to get someone in to have a look at it, I am a pensioner, and not able to pull the fridge freezer out of the unit.
    #445808
    look for an engineer on this site who can help you
    http://www.ukwhitegoods.co.uk/search/fi … e-engineer
    dgethin
    Thanks very much!
