CAPLE WDI1212 – error signal E14
Home Forums Public Support Forums Help And Support Washing Machine Help Forum CAPLE WDI1212 – error signal E14
  • #17191
    chirurgz
    Hi.
    I have a problem with my washing machine. What does error signal E14 means?
    #173293
    Re: CAPLE WDI1212 – error signal E14
    You have a problem with the temperature control circuit in the dryer. These SMEG-built appliances are notoriously difficult to diagnose, so if you can’t find anything obvious like broken wiring, I’d definitely get professional help.
    Power off if investigating.
    chirurgz
    I think problem is in NTC sensor. Ohm value is only 76Ω.
    Thank you, Penguin45.
