Does someone happen to have any technical specs/diagrams for this integrated washer dryer?
It’s not draining when on the drying cycle but the pump works fine on the wash cycle. Does anyone happen to know if these Fagor machines have a timed drain when drying or rely on a pressure switch?
The first job though when I return is to try and get it out….the builder had screwed it to the SIDE of the unit and then fitted the work top!! :rolls: I’ve already lost one long handled screwdriver down the back of the machine as I have tried to get the rear screw out in a gap that is not quite wide enough for my arm to go into. 😥
