Carbon brushes – how long?
Home Forums Public Support Forums Spare Parts Help Carbon brushes – how long?
  • This topic has 18 replies, 4 voices, and was last updated 12 years ago by alc.
Viewing 15 posts - 1 through 15 (of 19 total)
  • #80070
    alc
    Hi all,
    Just wondering how long carbon brushes should last? I purchased and fitted some replacement carbon brushes at the end of Jan/beginning of Feb this year. Today my washing machine stopped spinning, and on inspection the brushes have worn right down.
    The machine is used most days, but would you expect them to wear down in under 2 months, or is there something else which has caused it?
    Paul
    #411568
    Andy jones
    Re: Carbon brushes – how long?
    Should last a lot longer than that, clean armature before fitting or the armature itself maybe badly worn
    #411569
    alc
    Thanks. I didn’t clean it before fitting the replacements, so could be that I guess. I assume it’s one of these I need? http://shop.ukwhitegoods.co.uk/carbc01- … or-cleaner
    Are there instructions included on how to use it?
    #411570
    Andy jones
    Yep that’s the part.
    #411571
    It also depends on the quality of the replacement brushes, non genuine pattern spares can sometimes be of very poor quality. Rapid brush wear can also be a sign of a damaged commutator as Andy has said.
    What make of machine do you have?
    #411572
    alc
    It’s a a Hoover OPH148 washing machine which has a CESET MCA 52/64-148/CY44 motor fitted. I bought the sv1202-ceset brushes from ukwg. Thanks
    #411573
    Oh dear, chances are that is a Chinese made CESET motor, very suspect quality and very likely to be at fault.
    Does it say Made in China on the motor label?
    #411574
    alc
    Yeah, made in China
    #411575
    alc
    Should I think about replacing the motor?
    #411576
    Andy jones
    I would check condition of armature 1st. Give it a good clean and try another set of brushes
    #411577
    alc
    Thanks Andy, what am I looking for? There is a lot of carbon build up, but I cant see any big pits (although the carbon may be hiding this I guess!)
    #411578
    Andy jones
    Use the comm stick to give it a good clean. If motor is on the machine then hold the stick on the armature and spin drum by hand ( unplugged of course )
    If motor out then spin the pulley by hand
    #411579
    I have to say that I have recently had a success rate of less than 50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} when trying new brushes on these shoddy, Chinese motors and I clean the comm very carefully. 😉
    #411580
    alc wrote:Should I think about replacing the motor?
    I would think about replacing the machine if motor is faulty.
    #411581
    alc
    I’ve reseated the brushes and it seems to be working ok which will at least allow me to get the kids uniform washed for next week. The brushes are very worn though so I will get some new brushes ordered.
    Thanks for your help
