CATA box cooker hood, Designair – Are dimmable LED spots OK?
Home Forums Public Support Forums Help And Support Other Appliances CATA box cooker hood, Designair – Are dimmable LED spots OK?
  • #80863
    corkee
    Just fitted a CATA Designair 70cm box hood which has GU10 type spot bulbs – the touch control fades them up to fully on and down to off.
    Wondered if it is OK to fit dimmable LED spots instead?
    Realise that dimmable LEDs may need a special dimmer circuit, so don’t want to buy them if they could damage the existing hood circuitry?
    Thanks in advance..
    Colin
    #414651
    Re: CATA box cooker hood, Designair – Are dimmable LED spots
    It will void your warranty on the hood assembly.
    Bryan
    #414652
    And they may well not work.
    Dimmable LEDs are notoriously fickle and I can first hand tell that is true and they can and do interfere with electronics.
    Non-dimmable one’s aren’t a whole cheap better at times either.
    Then there’s the warranty issue as Bryan says.
    corkee
    Sounds like a no-no for now then.
    Maybe sometime in the future, they’ll invent one that is a direct replacement for quartz or tungsten bulbs, until then, I’ll leave well alone.
    Thanks for your advice
    Col
