Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › CATA (I think) Single Oven – UBOVF60 No Heat
- This topic has 13 replies, 3 voices, and was last updated 6 years, 4 months ago by
asp11.
November 13, 2019 at 6:25 pm #96725
asp11
ParticipantThis is a basic oven with a selector, timer and stat only….. The oven bulb went at the same time as this error.
The element is fine, all the wiring is fine, the switch has no burnt wires or connectors…. I have checked each wire from the switch to element, switch to stat, one side of the switch to the other and tmer plus have by-passed a toc and the stat but still nothing
It really can’t not work in my opinion, I have done the same checks 3 times in case I missed something – it just should work but it doesn’t
Any ideas please as I must be overlooking something here!!??
November 13, 2019 at 6:44 pm #464587electrofix
Moderatorfirst check for live and neutral coming in
then buzz it through one wire at a time. starts at the term block and buzz the wire all the way to the element. disconnect one wire of every component so you don’t get confused with back feeds
the switch contacts may look ok but did you buzz across the switch to make sure
November 13, 2019 at 7:00 pm #464588Specialist01269
ParticipantApologies if you’ve already done this, but there’s no mention of checking that you actually have 240v in to the appliance.
November 16, 2019 at 6:34 pm #464589asp11
ParticipantYes there is mains coming in and getting to the switch….. with the machine dead, I put my meter leads on the oven element, turned the switch and it bleeped so in theory the switch n wires should be good… thats why I’m confuded about my findings??
November 16, 2019 at 6:46 pm #464590Specialist01269
ParticipantSorry: Now I’m confused, what bleeped ? Do you mean your Multimeter ?. You need to see what voltage is on the display to know what is actually hitting the element, not rely on a beep to indicate voltage.
November 16, 2019 at 6:59 pm #464591Specialist01269
ParticipantSpecialist01269 wrote:Sorry: Now I’m confused, what bleeped ? Do you mean your Multimeter ?. You need to see what voltage is on the display to know what is actually hitting the element, not rely on a beep to indicate voltage.
Maybe a daft question, but are you sure that the timer is set to manual ?.
November 16, 2019 at 7:30 pm #464592electrofix
Moderatoras you realise you need to get a live and neutral before an element will work. the switch switches both live and neutral so a faulty contact on either of them will cause it not to work
if it was me I would teat live.
turn on mains, set timer to manual , turn oven selector switch on and turn up stat if separatethen go to the element . we need to find out whats missing so you will either have 2 lives or 2 neutrals. as you realise whichever you have its the other one that’s not there
still think its most likely a switch fault
November 16, 2019 at 8:04 pm #464593Specialist01269
ParticipantTotally agree, take it your old school as well then Dave ?. That’s the way I was taught (many moons ago), a couple of quick live tests can save an awful lot of guesswork.
November 16, 2019 at 8:10 pm #464594electrofix
ModeratorSpecialist01269 wrote:Totally agree, take it your old school as well then Dave ?. That’s the way I was taught (many moons ago), a couple of quick live tests can save an awful lot of guesswork.
was connecting to electric meters live at age 17
those were the daysDave
November 16, 2019 at 8:21 pm #464595Specialist01269
ParticipantAye, they certainly were
November 18, 2019 at 9:45 am #464596asp11
ParticipantThanks guys, you might be correct about the switch
Even though when turned to work the oven I’m getting a reaction at the element, when live it may not…. I’ll go back to test it again
November 18, 2019 at 2:56 pm #464597Specialist01269
ParticipantWhen you say reaction, can you explain ?. If you have a circuit through the element, probably in the region of 25 to 40 Ohms and 240v at the element connections with the element connected then your element should heat.
In this scenario continuity testing is not really any good to you.November 18, 2019 at 3:00 pm #464598electrofix
ModeratorSpecialist01269 wrote:When you say reaction, can you explain ?. If you have a circuit through the element, probably in the region of 25 to 40 Ohms and 240v at the element connections with the element connected then your element should heat.
In this scenario continuity testing is not really any good to you.you may have 240v at the element connections but unless one of them is 0v Neutral it wont work
November 18, 2019 at 4:01 pm #464599Specialist01269
ParticipantDave mate: If your testing at the element with a Multimeter or 2 pole tester and get 240v then the Neutral is there, otherwise the meter wouldn’t read. I’m not talking about testing to Earth from each leg, but directly across the Live & Neutral at the element.
