Cause of motor multi plug burnout?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Cause of motor multi plug burnout?
  • #98267
    Nathan Kidd
    I have a BEKO WTB941R2W washing machine that has failed to spin. I have found that the multi plug connected to the motor is completely burnt out, with a couple of wires being melted through.
    I have cut the multi plug off, and I am going to connect the motor back up using standard spade connectors. I will let you know the results. However I am wondering what could cause such a failure, as I don’t want it to happen again.
    #471640
    its not common but does happen
    has it been leaked on ? as that can do it
    we get problems with hotpoints doing this as they use poor connectors but not had a Beko do it
    its probably been a loose connector or it not been plugged all the way in or its been leaked on
    Nathan Kidd
    Thanks for the response Dave.
    Plugged the motor back in but no spin. I’ve a suspicion that it may be the DC module that is fried.
    Could a burnt out DC module also cause the multi-plug to burn out?
    #471642
    the only thing that causes motor plug burn is the plug or leaks
    Nathan Kidd
    Just replaced the DC module with a new one and, hey presto, a working washer.
    Strange, as there was little to no visible damage on the old DC module. No burnt out fuses, just a bit of blackness around one of the “capacitors”.
    #471644
    can be stupid
    bad solder joint or hairline crack on board
