Home › Forums › Manufacturer/WP/Insurer Specific Forums › ISE Trade Support Forum › cd601w no display and others
- This topic has 5 replies, 3 voices, and was last updated 12 years, 1 month ago by
mike100.
February 15, 2014 at 10:35 am #79541
mike100
Participantseen this as cutting out. Found door coming open so will order Lock/Push. Also leaking as when water tank pushed in the fixed pipe is not directing water into tank.
Is there a flexible pipe to direct water?Also there is no display. Do i need to replace control unit or is there an easier option
Thanks,
Mike
February 15, 2014 at 4:53 pm #409614timdowning
ParticipantRe: cd601w no display and others
That’s quite a lot of info to try and work out what you mean and in what order this all happened. No display can be door related and stat related. Unlikely to be board.
March 4, 2014 at 1:01 pm #409615mike100
ongoing problem here.
Leaking from left rear
Also, there is only a display on Timed Dry and Revitalise.
Delayed start timer works ok.
Fitted new door catchCan you tell me please how to access the pump reservoir. It looks like the back has to come off and the drum taken out. Not easy i suspect
thanks,
Mike
March 6, 2014 at 12:21 pm #409616mike100
Participantcd 601w leaking and no display
Leaking from rear left and no display except on Timed Dry and Revitalise.
How do you access the reservoir that may be blocked. Do you have to take off the back and drum out.
Thanks,
Mike
March 6, 2014 at 12:52 pm #409617timdowning
ParticipantRe: cd 601w leaking and no display
Yes back off to get to pump. You should be able to access it without removing drum.
March 25, 2014 at 12:19 am #409618kwatt
KeymasterRe: cd601w no display and others
Since I’m on a roll tonight for upsetting people it seems.. 😉
I think that we had this “customer” on the phone today being particularly unpleasant. Then the follow up snide emails. Given free reign I think I may be just as unpleasant in return but, I’ve not done so. Yet.
I was asked to leave it be.
I was unaware of these thread, that I’ve now merged to prevent confusion because the customer mentioned it in an email.
A condenser dryer leaking and cutting out.
Why will it cut out is the first question I’d ask and, the logical explanation would be that, for some reason that it is overheating and tripping on the overheat. Then the question becomes, why is it overheating?
Now consider that it is “leaking”. On a dryer the only place water can come from is either the laundry put in it or from the environment from condensation, there is no other source of moisture. Or at least, there shouldn’t be.
To cut a long story short and save a whole bunch of hassle for you, what I’d guess and I’d be pretty confident was correct, is that the machine hasn’t been cleaned out correctly and that it’s gotten clogged up with lint. That will be blocking the pump or the airways restricting airflow and causing the machine to cut out and, quite probably blocking either the lifter pump or one of the hoses.
It’s about the only logical explanation for the symptoms.
This is pretty common in commercial use because very often staff don’t bother their backsides to clean them out, especially the condenser unit as regularly as they should.
Of course until you open it up and look though, you won’t know for sure but I’d be willing to bet that’s the cause.
If it is, you can charge the owner whatever you like for cleaning up their mess.
