CDA 494. Fills with water, nothing else
Home Forums Public Support Forums Help And Support Dishwasher Help Forum CDA 494. Fills with water, nothing else
  • #33325
    tryanything
    Closing the door, the machine bleeps once. Starting the program (any program, it doesn’t matter) The drainage pump runs, followed by the machine filling with water. This is when nothing else occurs. The main jet pump is not heard to run. The ‘Start’ button then flashes 6 times. Resetting the unit will allow you to drain the unit, but the fault still occurs. I have removed and inspected the main jet pump, and impellor is free of movement and all intact.
    I don’t know if this is linked, but approx 3 weeks ago, the machine stopped mid cycle, ‘start’ button flashed 8 times, but all was cured with a reset….
    Have you got any ideas
    #238309
    Re: CDA 494. Fills with water, nothing else
    This is the usual problem:
    http://www.ukwhitegoods.co.uk/modules.p … eter+metre
    Power off if you intend to resolve this yourself.
