CDA 601/2 SS Grill Oven – new Element installed but only one works at a given time
Home Forums Public Support Forums General Enquiries And Questions CDA 601/2 SS Grill Oven – new Element installed but only one works at a given time
Viewing 15 posts - 1 through 15 (of 17 total)
  • #102556
    to5h
    I have recently installed a new Element on my Electric Oven Grill, however when i have the setting on grill oven, only the outer element work, but when i change it to oven, then only the inner element works. I have been trying to figure out why both doesn’t work, as it used to before the change.
    Any ideas? Could it be thermostat?
    #489408
    sounds like you may have put the wires back incorrectly
    to5h
    Thanks Dave
    I did take a pick before i removed the wires, so followed them exactly how i took them out
    #489410
    double check you have them correct
    normally the grill element is just the middle element unless the cooker has to grill settings in which case small grill is just the middle and large grill is both elements
    in convection oven mode only the outer element is used
    to5h
    Hi Dave
    Thanks for the message, just checked the connections and this is how they look
    before replacing
    and now
    Thanks once again
    #489412
    well that looks like its correct
    so if you set it on small grill which element works
    to5h
    Thanks Dave,
    On number 1, the outer element works an on number 2 the inner element works
    #489415
    to5h wrote:Thanks Dave,
    thats correct
    no 1 is convection oven. uses outer element plus another element under the floor
    No 2 is grill which is the inner element
    to5h
    Thanks Dave
    So do both elements not work together? Before the replacement the oven used to get much warmer (hotter) and both elements used to work at the same time, so i have been told by the missus.
    When you say,”plus another element under the floor” what do you mean? Should there be another element i might need to consider?
    Thanks once again
    #489417
    when working as an oven it works with 2 elements and one is under the floor of the oven
    get lots of them where customer complains oven does not get hot enough and the lower element has failed
    dave
    #489418
    to5h
    Thanks Dave,
    Apologies for asking stupid question, but where do i find the this “under the floor of the oven” element?
    Or is it the back where the fan is? Like in the diagram?
    #489419
    your oven is a multi function oven
    you can use it in fan oven mode or convection mode or convection fan mode
    fan mode uses an element at the rear
    convection mode uses top and bottom elements
    lower element is probably this one
    https://shop.ukwhitegoods.co.uk/062090004-oven-bottom-element
    to5h
    Thanks Dave for the message
    I have had a look at the oven and cant see an element like that within it.
    I replace the only element i could see, it looks like this
    And this is the link to the manual for CDA 601/2 SS
    https://manualzz.com/doc/66309706/cda-cd601-single-oven-user-manual
    Thanks once again
    #489421
    you cant see that element because its under the floor
