Home › Forums › Public Support Forums › General Enquiries And Questions › CDA 601/2 SS Grill Oven – new Element installed but only one works at a given time
- This topic has 16 replies, 2 voices, and was last updated 2 years, 2 months ago by
to5h.
January 31, 2024 at 9:29 am #102556
to5h
ParticipantHi
I have recently installed a new Element on my Electric Oven Grill, however when i have the setting on grill oven, only the outer element work, but when i change it to oven, then only the inner element works. I have been trying to figure out why both doesn’t work, as it used to before the change.
Any ideas? Could it be thermostat?
January 31, 2024 at 9:49 am #489408electrofix
Moderatorsounds like you may have put the wires back incorrectly
January 31, 2024 at 10:16 am #489409to5h
ParticipantThanks Dave
I did take a pick before i removed the wires, so followed them exactly how i took them out
January 31, 2024 at 10:49 am #489410electrofix
Moderatordouble check you have them correct
normally the grill element is just the middle element unless the cooker has to grill settings in which case small grill is just the middle and large grill is both elements
in convection oven mode only the outer element is used
January 31, 2024 at 11:57 am #489411to5h
ParticipantHi Dave
Thanks for the message, just checked the connections and this is how they look
before replacing
and now
Thanks once again
January 31, 2024 at 12:31 pm #489412electrofix
Moderatorwell that looks like its correct
January 31, 2024 at 12:32 pm #489413electrofix
Moderatorso if you set it on small grill which element works
January 31, 2024 at 1:28 pm #489414to5h
ParticipantThanks Dave,
On number 1, the outer element works an on number 2 the inner element works
January 31, 2024 at 6:59 pm #489415electrofix
Moderatorto5h wrote:Thanks Dave,
thats correct
no 1 is convection oven. uses outer element plus another element under the floor
No 2 is grill which is the inner element
January 31, 2024 at 10:56 pm #489416to5h
So do both elements not work together? Before the replacement the oven used to get much warmer (hotter) and both elements used to work at the same time, so i have been told by the missus.
When you say,”plus another element under the floor” what do you mean? Should there be another element i might need to consider?
Thanks once again
January 31, 2024 at 11:03 pm #489417electrofix
Moderatorwhen working as an oven it works with 2 elements and one is under the floor of the oven
get lots of them where customer complains oven does not get hot enough and the lower element has failed
dave
January 31, 2024 at 11:24 pm #489418to5h
Apologies for asking stupid question, but where do i find the this “under the floor of the oven” element?
Or is it the back where the fan is? Like in the diagram?
February 1, 2024 at 12:04 am #489419electrofix
Moderatoryour oven is a multi function oven
you can use it in fan oven mode or convection mode or convection fan modefan mode uses an element at the rear
convection mode uses top and bottom elementslower element is probably this one
https://shop.ukwhitegoods.co.uk/062090004-oven-bottom-element
February 1, 2024 at 8:41 am #489420to5h
ParticipantThanks Dave for the message
I have had a look at the oven and cant see an element like that within it.
I replace the only element i could see, it looks like this
And this is the link to the manual for CDA 601/2 SShttps://manualzz.com/doc/66309706/cda-cd601-single-oven-user-manual
Thanks once again
February 1, 2024 at 9:50 am #489421electrofix
Moderatoryou cant see that element because its under the floor
