I have a cd9002 cooker and the bottom element needs replacing.
I have had the back off and the side panal but can not see any obvious way off accessing the element. Can anyone help.
thanks.
Is the 9002 a range, if so open the panel below the oven where you can store baking trays ect and the element is clipped in with 2 bars. You will still need to get to the terminals at the rear. Dont forget to turn the power off before working on electrics.
