CDA CI592WH Washerdryer doorseal fitting Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › CDA CI592WH Washerdryer doorseal fitting This topic has 3 replies, 2 voices, and was last updated 18 years, 1 month ago by Simon46. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts February 24, 2008 at 6:19 pm #34822 Simon46Participant Has any body managed to fit the doorseal on one of these Siltal produced machines without removing the drum assembly? Regards Simon February 24, 2008 at 6:54 pm #244117 adminKeymaster Re: CDA CI592WH Washerdryer doorseal fitting Yep dont use washing up liquid though !!!! it’ll keep coming off. Start at the top and work down. Bryan February 24, 2008 at 7:00 pm #244118 Simon46Participant Re: CDA CI592WH Washerdryer doorseal fitting Ta Bryan. What is the inner clamp band type? Garter or bolt? If bolt would a flexidrive help? S. February 29, 2008 at 8:44 am #244119 Simon46Participant Re: CDA CI592WH Washerdryer doorseal fitting All done 😀 . Found a tiny ratchet and socket/posidrive bit helps to undo clamp band. Ta Bryan. S. Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
