CDA CI930
  • #81210
    msappliance
    Having this washer dryer flash fo7 blockage fault, pressure pipe clear. has any one changed the switch to solve this?
    thanks
    Mike
    #415780
    agwarn
    Re: CDA CI930
    Check the connections to the drain pump (and the drain pump itself), I believe you can get F07 if the pump goes open circuit.
    Otherwise try a pressure switch as you suggested 🙂
