CDA CI981 No power
  • #101503
    Kristoffer10
    My washing machine (CDA CI981) was an a regular cycle and then I went to put in on a spin, there was no power to the machine.
    I press the on/off switch and nothing happens.
    I have changed the fuse on the plug, all the other appliances in the kitchen work fine. The socket that the machine plugged into works fine also.
    Does anyone have any suggestions to what might be? I also left it unplugged for a while in case that would help.
    Any points in the right direction would be greatly appreciated. Many thanks
    #484999
    if as you say the socket is ok your looking at a problem in the machine
    mains flex
    supressor
    main control board ( can sometimes be repaired if the engineer who looks at it can sort electronics )
    Kristoffer10
    Thanks Dave, much appreciated, will investigate what I can within my ability.
