CDA CI993 door staying locked when half load is on
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries CDA CI993 door staying locked when half load is on
  • #48160
    pmb
    Hi on a CDA CI993 the door locks whenever the half load button is on. it even does this if the machine is off and the door is unlocked and you push the half load button the door will lock. I have checked that the wash heater isn’t down to earth along with anything on the dryer. The machine seems to work fine otherwise. I am thinking it must be the timer but as it is special order with masterpart i thought i would see if anyone can give me some advice thanks Peter :lesson:
    #295801
    Re: CDA CI993 door staying locked when half load is on
    That’s plain weird…. I’d be asking myself,
    “Who’s been in here before me?”
    pmb
    🙂 it is weird isn’t it, i am sure no one else has touched it though its through a letting agent i have worked with for 15+ years and i sold the machine to them. Thanks Peter
    #295803
    pmb
    Hi i still haven’t solved this so i will have one more try, any ideas? any help would be really appreciated
    Thanks Peter
    #295804
    timdowning
    Do you need to have the half load button pressed in to get the dryer to work?
    #295805
    pmb
    Yes it does otherwise i would bypass it 🙂
    #295806
    pmb
    Went back and it has now changed, half load button doesnt affect it
    But now you have to press off button and wait 2 minutes for door to open.
    Its in a rented flat and they insist it has to be perfect.
    #295807
    timdowning
    That two minute wait is normal isn’t it?
    Can you get the manual for it?
    If it isn’t normal you have to start by changing the lock?
    (Long shot but do try plugging it in another socket)
