CDA cooker hood
  • #97853
    rojreese
    Motor failed, where can I get a replacement? Its part number is JYCY-155A5 and is not listed anywhere on the web. Help appreciated
    #469841
    Ring CDA
    and if they cant supply then no one can
    rojreese
    I have stripped the motor and cleaned the bearings. The motor turns the fan but it runs quite slowly on the third setting. Could the capacitor be faulty?
    #469843
    i have known cooker hood caps to go so yes it is possible
    peterpan
    I am having problems with this same motor and cannot find a replacement. It was barely moving so I have managed to free it up. I am wondering if it is worth putting back in. I was going to get a new one and keep it as a spare?
    #469845
    as i stated above ring CDA and ask
    as for putting it back well the answer is maybe
    depends how well lubricated you have got it and how long this last. if its just WD40 then probably wont last long as it need to be proper light lubricant. After that its luck how long it lasts
    peterpan
    Thank You. Rang CDA this morning, excellent service and new motor arriving this week.
