CDA Cooling fan on its way out ?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum CDA Cooling fan on its way out ?
  • #100366
    menderman
    CDA 9002/1
    On sorting out some other issues with the oven I realise that the cooling fan is quite noisy, goes through sort of a purring sound (but not a nice purr ) that goes up and down in volume and intensity. The nearest example I can find is this https://www.youtube.com/watch?v=NxCGXGHI94o the first 20 seconds but mine is a little softer noise.
    So am thinking of a pre empted replacement but its a duel fuel gas hob and it sits under the hob burners. Can a replacement be done without removing the the gas burners part. ?
    #480329
    check the fan, a lot of the time the fan rotor slips away from the motor and rubs on the end frame
    since its only a rubber grommet holding it you can normally push it towards the motor a bit to stop it
    possible part
    https://shop.ukwhitegoods.co.uk/d805010-compatible-oven-cooling-fan-motor
    #480330
    menderman
    Thanks for your help
    #480331
    menderman
    possible part
    https://shop.ukwhitegoods.co.uk/d805…ling-fan-motor
    Yes that is the part and my oven is listed there.
    Any thoughts of fitting that compatible part instead of the twice the price OEM one.
    Also I think I am looking at a gas safe engineer because from what I can see the hob burners have to be removed so if the compatible one packes in then its extra labour to replace again 🙁
