Unit Has first 4 red LEDs on left hand side (flashing) on and green led on right side on (permantent), It gives of 6 beeps. Unit will pump out so don’t believe that it is a pump that is causing this, Any ideas?
Flood protection activated – base tray under machine has water in it. Power off, towels down and tip it to one side. If the problem repeats, find the leak.
Well, it’s Chinese, so anything is possible. I’d start by getting rid of the multifuction tablets and using a low froth product like Fairy Bursts (and rinse aid) and seeing how you go.
