CDA cw195/1
  • #37958
    bazza500
    Went to this dishwasher today. Put it through a test and it came up with 5 flashes. The technical info does not mention 5 flashes, it jumps from 4 to 6.
    Any one know what 5 flashes represents?
    If I try and start a programme, it drains, fills and then drains, beeps and shuts down.
    Any help would be appreciated.
    #257259
    DentedPorsche
    Re: CDA cw195/1
    Hiya,
    If it’s the Whirlpool machine then 5 flashes indicates a blocked spray arm. Haven’t come across it before though.
    Brian
    #257260
    woz
    Re: CDA cw195/1
    yep dented it right these new machine are highly dependent on the wash pump….. these machines have no pressure stat or other water level indicator it relies on sensing the currant drawn from the pump to sense the pressure of the water if the spray arms are blocked the pressure is too high so it drains and shuts down.. also if its syphoning etc etc this is just the /1 versions
    cheers
    woz
