cda cw492
  • #35800
    deej
    my dishwasher is flashing twice, is this a code!! can you help, it wont work!!? cda cw 492 🙁
    #248141
    Re: cda cw492
    Whirlpool-built machine, so two flashes indicates that the flood protection system has been activated. This means that water has leaked into the tray under the machine.
    You need to drain the tray to reset the machine, then have a look for the leak.
    Power off before removing any panel, please.
    deej
    Re: cda cw492
    Thankyou penguin45… will try that! watch this space
    #248143
    deej
    Re: cda cw492
    ok…..? i’ve found the filter tray and removed that. have 4 small and 4 larger screws, do i remove these or do i have to go underneath? 😯
    #248144
    Re: cda cw492
    If you undo those screws, the sump will fall off………
    Remove decor door (screws 2+4 on the inner door panel). Remove front lower panel to reveal the tray under the machine. Power off and mop up. Try running the machine and use a torch to keep an eye on what is happening – especially ths little horror.
    deej
    Re: cda cw492
    This appliance is semi integrated has wooden panel on front. just plinth covering the lower part with two screws in…is this what i remove or still the door panel?
    #248146
    deej
    deej wrote:This appliance is semi integrated has wooden panel on front. just plinth covering the lower part with two screws in…is this what i remove or still the door panel?
    no water in tray. machine is clicking on and off but no dishwashing sounds!
    #248147
    Re: cda cw492
    You won’t get at the lower cover with the decor door in place – it laps over. Any wooden plinth in front of the machine will have to go – you are trying to get to the lowest point of the machine.
