Can anyone tell me where to obtain spares for these.
I need to price for replacement of main pump and mainPCB.
The story of this machine is worth telling, It is a fully intergrated machine the installer connected waste to sink waste pipe, yes you guessed it waste pipe runs straight down to machine so when sink emptied machine fills with waste from the sink, This is where it gets interesting the machine has a pan underneath to collect leaks from machine but there is no flood protection switch so the pan just fills up with water, The main pump motors electrical connection is positioned underneath the motor so that when pan fills up with water there is no flood protection so pump motor plug is then submeresed in water blows motor plug which then blows main PCB. Which plonker designed this one? CDA you should hang your head in shame.
Bassman
